I’ve purchased and have been using the Aluminum Gator Tooth Clamps. They’re pretty nice, but I’m finding that the Button-Heads of the 1/4-20 screws grind into the side walls of the clamps when tightening. The clearance for the head of the screw in the channel is way too tight. They still work, but it seems like another iteration of the clamps should better accommodate for the screw heads. Thoughts?
I have the stainless version and they have enough clearance for the screw. It’s very close, but they do drop in nicely. The difference could just be in their programming differences for the materials though. I don’t see why the counterbored slot couldn’t be 0.02" wider though.
I had the same problem with my batch. From what I can tell it’s actually bad tolerances on the screw heads. Out of all the screws only a few had the issue. Thankfully it’s a cheap fix to get some new ones.
