Get a Grip Workholding Kit Dimensions
I just got the Get a Grip Workholding kit. I am prepping to drill the holes to mount the pieces; has anyone already measured and tested the dimensions?
The plastic L bracket is different than the aluminum one, so the old file I found earlier doesn’t work.
I emailed support, and they said they don’t share the dimensions.
I will make a jig and can post back my results.
This is what I have so far (all in mm):
Brackets
  • bolt diameter: 6
  • bracket length and width: 120
  • bracket width: 20
  • bolt spacing, center to center: 99.5
  • hole at origin corner: 2.75
  • bracket thickness: 4
  • circular recess diameter: 19.75
  • circular recess height: 5
Lock Stop
  • circular recess diameter: 24.75
  • width:32
  • depth: 30.5
  • height:9
  • center of bolt to front: 14.75
