Glass - Engraving tool options
I tried the McEtcher today on glass with good results, at least better than I expected on a first try.
I set the spring to 1 full turn in and used the default values in CC.
I coated the glass with 3in1 oil, definitely sounds better wet.
I was wondering if anyone has tried the 501 or 502 engraving bits on glass.
The thought is to create a single thicker line.
I can use multiple passes with a Contour with McEtcher or create a narrow Pocket and the McEtcher.
I haven’t done much mechanical etching on glass or mirrors so I don’t have much experience to offer on that front.
That said, I was wondering if you have ever used Armour Etch glass etching cream? It might be a decent solution if you don’t mind the uniform frosted/bead blasted look.
You could use the Carbide3D Stingray vinyl cutter for getting relatively clean stencils. Should be cheap, quick, and straightforward…plus no need to work hold your fragile glass :wink:
Glass etching cream certainly isn’t the best approach in every case but I’ve found that most folks haven’t even heard of it. Figured it’s worth mentioning at the very least.
And now I want to try mixing elements of the mechanical and chemical approach. I bet there’s some interesting visuals somewhere in there :slightly_smiling_face:
I have come across the etching cream, but no clue on usage.
You comment on a mixed approach is interesting.
Using the drag bit for larger areas is time consuming and would never give the same presentation as chemical ( I assume ).
I have a drag knife that is still in the box.
I am told there are different path generation requirements for a drag knife to work correctly.
My wife has a cutter for a mask.
That maybe the after Christmas project…
