I searched for this topic but didn’t find anything here. I’m using grayscale images as height maps. After I go through the process of adjusting and tweaking the settings of the “Model” the model eventually shifts from it’s position. Usually after the second tweak or second time interacting with the settings, if that makes sense. I can reproduce this with every model I’ve tried. I set the parameters. Check the 3D view. Back to settings and adjust. Model shifts. Anyone else have this problem?
Please upload a file and step-by-step instructions for causing this and screengrabs showing what you are doing at each step and what is happening and we will do our best to look into this with you.
Height Map Shifting_CCPro.mov.zip (3.7 MB)
Here’s a screen recording showing it in real time. Mac OS Monterey 12.7.6 running Carbide Create Pro Build 841, Built on: 2026-02-20
The file is above 4MB so it’ll not let me upload it. Here’s a dropbox link: https://www.dropbox.com/scl/fi/ne5u4oiqfspsa7u0mjhuv/CarbideCreate_Forum_Spoon.c2d.zip?rlkey=akhbb9gegt3w8adafpx6v84vc&dl=0
Yeah, happens to me a lot. After you import a model and click done, CC doesn’t like you fooling with the model. It becomes annoying at times especially if you decide you want to change a rotation or location. I’ve had the issue happen since my beginning with V7. Although I’ve never narrowed it down to how many tweaks cause it.
