Hi, I would like to update my shapeoko 3 without home switches from grbl 0.9 to grbl 1.1.
Is there a easy way to do this ?
Is it possible use this guide http://docs.carbide3d.com/support/carbideupdater// without z limit ?
Is enough make a bridge between z limit pins instead of hold z limit ?
Thanks all!
Fil
Yes, just bridging that should allow the Carbide Updater program to work — but you’ll still need homing switches to use Carbide Motion 4, so if you don’t have them, you’ll need to use a 3rd party program. List at: https://www.shapeoko.com/wiki/index.php/Communication_/_Control (there are also some commercial ones listed at: https://www.shapeoko.com/wiki/index.php/Commercial_Software#Communication.2FControl.2FG-Code_Interpreter
Ok thank you!
So a jumper between two z limit pinout is enough ?
I will try with Chilipeppr!
