I’m having this issue. My machine doesn’t have much time on it. I rarely use it. I have updated all the software. It doesn’t matter how many times I restart and initialize. Hangs in the middle of the initialization. I did figure out a workaround. If I turn the system off, unplug it from the computer, and manually roll it to a center position. It will initialize after that. I don’t understand why this is happening and why this seems to fix it. Thoughts?
This indicates that the machine was reset while a homing cycle was running. The machine position will be lost, but you can re-initialize the machine to clear this error.
Things to check:
- machine is well-lubricated and in good condition:
https://carbide3d.com/hub/docs/maintenance/
belts are securely anchored and correctly tensioned and pulley set screws are secure and in place
all wiring in good condition and all connectors secure
