GRBL Alarm 8 Code - Homing Fail
Just received my machine 2 weeks ago. I would not run so Carbide sent me a new controller and I was able to run 2 test jobs last weekend - everything was great until…
Tonight I go out to the shop as I need to get some wedding projects done this weekend and I get a GRBL Alarm 8 all of a sudden…what do I do. I am new to a CNC however since I have had this machine for 2 weeks I am continually having problems.
I would appreciate any help you can direct my way
There is a list of error codes at:
https://my.carbide3d.com/faq/error-codes/
and for Error 8:
GRBL Alarm Code 8 - Homing fail
Pull off travel failed to clear limit switch. Carbide Motion does several checks to avoid this error so it is very rare in a Shapeoko or Nomad CNC machine.
and it has a link to:
https://my.carbide3d.com/docs/troubleshooting-homing/
for this.
I am not sure what you want me to do. This is pretty frustrating having all these problems in the only 2 weeks I have had the machine. Hopefully things get better.
If the troubleshooting page doesn’t help, write in to support@carbide3d.com and we’ll work through this with you.
I’m new to cnc as well. Just got started with my machine a few weeks ago. I sometimes get an error when I hit my limit switch, I am able to move back off the switch, causing a second alarm but it moves fine after resetting the second alarm.
In the beginning I had issues with hard and or soft limits causing issues, I turned them off and all is well so far.
I know there probably correct ways to fix this, but this is how I work around. I dont get an error when I home.
ok thank you for your help
