I’m using fusion 360 to generate toolpaths with the Carbide3d post processor. During an adaptive clearing toolpath, I get the following error in Carbide motion: “GRBL Error: A G2 or G3 arc was commanded but there are no XYZ axis words in the selected plane to trace the arc”.
That is post processor related. Which post processor are you using?
Generally this comes up if the post processor is one that outputs in inches. GRBL speaks metric, so when it does the conversion, it can have some calculation issues with the small movements in arcs. I usually work in imperial, but use the mm post processor for all programs.
