I get this error when homing grbl error: not idle
Which version of Carbide Motion are you using? If not a current one, please update:
https://carbide3d.com/carbidemotion/download/
and if need be, try the beta:
https://carbide3d.com/carbidemotion/beta
Please power everything down and try again.
If you have a repeat of this using the sequence outlined in:
let us know at support@carbide3d.com and we’ll do our best to puzzle out the difficulty w/ you.
i get grbl versions prior to 1.1 are not supported with both versions
Oh, you have a machine w/ Grbl 0.9.
You’ll need to use CM366/368:
https://carbide3d.com/downloads
if you wish to update to 1.1 and use a more recent version, check in at support@carbide3d.com
I think my problem is i also use computer for a laser. It seems the cnc is trying to home like the laser. How do i send a grbl command to change the value to home. It’s $22 43 on the laser?
how do i update 1.1. Right now my machine is useless
Write in to support@carbide3d.com and we’ll do our best to sort this out w/ you.
You’ll need homing switches, and a 64-bit computer running Windows or Mac OS X.
hi it’s been over week wonder if i’ve been forgotten. Dying to get back to using my cnc:(
I’m curious, which CNC machine do you have?
nomad 883 pro 2014 …
