I was running a job (simple surfacing op generated in VCarve), and got this error in the GRBL console (in CNCjs):
G1X-0.8000Y-2.8914 (line=3161)
error:2 (Bad number format)
I can’t see what’s wrong, and looking at line 3161 in the g-code file, it looks absolutely normal and is in the middle of a bunch of very similar G1 moves:
It does not seem to be a control/hidden character on that line either, that line only has the normal carriage return / line feed like the others:
Good question. Actually, I ran this from CNCjs, the only effect was that the job paused, I clicked resume, and it proceed normally so I did not bother re-running the file. I have had this happen on a few different files quite randomly (and only a couple of times) recently, but I guess if it was a datacom issue, I would expect GRBL to not print the line correctly ? (i.e. the error output is from the GRBL console, so those correct values arrived in the controller without being corrupted). It is still possible that a comm glitch introduced a weird non-printable character I guess…
EDIT: I tried; and unsurprisingly the file executed with no error in check mode. I guess this was a transient comm error, mmh. Still puzzled how GRBL could have printed the correct line on its output console though. I’ll monitor the issue.
