GRBL settings after 1.1 upgrade
I just finished flashing GRBL 1.1 to my board. Everything went as advertised. I use Universal Gcode Sender. I tried a couple of jog moves and a $H homing command and the machine acted very strangely.
That’s when it struck me… I didn’t first save a copy of the old GRBL settings so that I could make changes to the new defaults. A quick $$ displayed the current “new” settings, but without the original settings I’m unable to use the machine.
So… I’m asking if anyone can direct me to a list of what settings I should have for the XXL. I’ve changed the $22=1 “Homing” as well as the $130 thru $132 to 850, 850 and 80 for “Max X, Y & Z travel”.
I’ve read through most of the posts after searching for “GRBL settings” and haven’t found what I need.
Thanks in advance for any help.
Bill
We should have these numbers at: https://docs.carbide3d.com/software-faq/shapeoko-3-default-grbl-settings/ and https://docs.carbide3d.com/shapeoko-faq/shapeoko-enable-homing/
The numbers you note seem fine.
As usual, thanks Will. That’s what I was looking for.
Thanks again.
Bill
That’s why the directions instruct you to run CM and send the settings again…
