I set up my Shapeoko 5 Pro 4x4 today. Everything works good so far; however, the “C” on the the right rail does not illuminate. It flashed once for about .1 seconds, then nothing since. Any ideas?
If the machine is working it is likely a loose connection on the “C” light. Talk to support.
Check to make sure the E-Stop button isn’t pushed in.
E-stop is not pushed in and connections appear good/solid. Just realized my bitsetter is not lit up or functioning either. Maybe a bad board on the front?
Support,
Any resolution with this? I am having the same problem. No C lit up and bit setter not functioning.
Ths happened after installing VFD Spindle Kit.
Thanks
The resolution is to contact support@carbide3d.com and to work with us to determine what needs to be replaced.
