Does anyone know where I may be able to find a file to very lightly carve some registration lines in my Pro XXL spoilboard? Just wanting to use the on bigger carve to make sure my piece is parrallel to the x and y travel.
This would be a great exercise to get familiar with Carbide Create and do it yourself.
Set your workpiece to 33" x 33"
Create a horizontal line at the bottom, and a vertical line on the left edge
Use the linear array command to copy the lines each inch (or desired spacing)
Use a contour path with a Vee-Bit and No Offset set the the depth you want to cut.
Jog both axes to the extreme front-left & set zero on the top of the spoil board.
Let 'er rip!
