How would i go about grounding my spindle? Is there a common ground in the board i should use or just run it to an outlet ground?
EDIT: See the post below which has the specifics of which pin is grounded.
I grounded the spindle and “Z” plate to a separate ground on my Pro.
Well it’s new HDM. I was under the assumption that the spindle was grounded but that does not appear to be the case. I’m not using a bitzero but i see that there is a ground on the board connector for it. Should I run the ground to this pin?
Please check in w/ support@carbide3d.com on that, unless @Luke comments here.
Please email support with pictures. Pin 4 should be grounded and it goes to the VFD not a board
