Guitar body feeds and speeds help
gtr.c2d (874.4 KB)
What material are you cutting?
Which machine do you have?
How will you be holding the stock in place?
It’s a hardwood. Made up of black mahogany yellow Osage and ash.
Shapeoko 4xl
Double sided adhesive on the back. Carbide3d supplied clamps and I will secure some pieces of plywood to my hybrid table.
I also have a couple of the following bits. But they are super long. I saw a video done with thick stock on a standard length bit.
I did a test run with a body made up of laminated beam. Worked pretty well. But my speeds are too fast.
https://mail.google.com/mail/u/0?ui=2&ik=ec9b19c703&attid=0.1&permmsgid=msg-a:r3546736976205594984&th=1852b3efedc05b4b&view=att&disp=safe&realattid=1852b3c0dac327111051
https://mail.google.com/mail/u/0?ui=2&ik=ec9b19c703&attid=0.2&permmsgid=msg-a:r3546736976205594984&th=1852b3efedc05b4b&view=att&disp=safe&realattid=1852b3e3aed49596f0a2
If you take a look at the pic of the body, it dropped the bit right by where the neck is inserted…up to that point it was perfect.
Here’s the result. Slowed it down quite a bit. And it worked really nicely
Murray,
Looking great so far. Looking at that first photo, the router is quite a ways up into the mounting block. It’s hard to tell from this angle but be sure your router is in full contact with your mounting block, if you can afford to.
