I followed the todo instructions for this spindle controller but I cannot get and of the X inputs to run the spindle as per instructions
Can anyone point me to an obvious issue?
Many thanks
Many thanks
Which machine do you have?
Try bypassing the homing switches per:
Bypassing Homing Switches
at:
https://carbide3d.com/hub/docs/troubleshooting-homing/
Can you make the X-axis move then?
Contact the folks at support and we will work through testing things with you.
this is reference to the input functions of the H100 spindle controller not the X-Axis movement of CNC. I’m having issues with getting the Gcode controller activating the spindle with and external spindles speed controller.
