Hanging with Key Hole Slots
Not sure you could do a key hole slot. The thinnest slot is possible but dropping a larger bit in and then run it across the slot at the end it would retract and make two big holes, one at each end, and defeat the key hole by having a double large hole.
It may be easier to do t his manually with a plunge router and a key hole bit.
