Hardware or software issue
Hello everyone, so just started having this issue and not sure if it is a hardware issue or software issue. I’ve cut this file before same file, same tool path but now I am getting these pesky circles.
Almost certainly hardware. What machine /spindle do you have? If it’s an ER system, have you checked that the collet is properly seated?
Shapeoko 5 pro and using the router that came with it. I will take a look at the collet. I have debated getting the spindle upgrade but haven’t looked too much into it.
Is the bit old? Have you tried another bit
Which software?
I was using 60° fairly new sharp tip still, not flat. Software carbide create 7. I’ve cut the same file and same settings before no issues.
Possibilities are:
  • worn tooling
  • worn collet
  • tool came loose
  • machine needs lubrication
https://carbide3d.com/hub/docs/maintenance/
I mention that last only to cover all bases — doesn’t seem likely to me.
Alrighty, looking like hardware. I pulled the collet out and lo and behold 2 issues, looks like damaged collet and also chip buildup I don’t notice. Will do another project and see if that solves it.
