Please share
ND105-PR_4_passive_radiator_outline.dxf (185.7 KB)
Here ya go. ![]()
Thanks. What is the size in mm. of the DXF (should be 105 mm. wide) ?
I modeled it from that drawing, so yes, 105mm
Do I need to add 1 mm. to make the radiator fit in the pocket ?
I scaled it 1.01 just to be safe
I would try cutting it at your 1% (1.01 scale) & see how it fits.
It really depends on the tolerances used when manufacturing the bezel.
If it doesn’t fit, adjust the curve & recut with a profile (contour) cut. (Adapt & Overcome
