KennyW
(kenny)
1
Got back from a 4-month tour of duty and went to download the 548 build on my new computer and I keep getting the following prompts :
“Machine controller restarted unexpectedly”
“GRBL error, homing failed, couldn’t find limit switch”
“Homing cycle failed”
I have a Shapeoko 3 XL and unplugged the Machine while I was away. Not sure what to do.
mhotchin
(Michael Hotchin)
2
It sounds like you are having problems when you go to ‘Initialize’, is that right?
What happens on the machine? Are things not moving, or are they moving and not stopping when they hit their physical limits?
KennyW
(kenny)
3
Correct, I hit initialize and the router will move down in the z position and stop after a few inches and all the errors will then pop up.
Julien
(Julien)
4
Try connecting but not initializing, and resending machine configuration ?
KennyW
(kenny)
5
Just tried unfortunately did not work.
KennyW
(kenny)
6
After going through the set manual again I realized I had uploaded the wrong configuration data. thank you. I R Dum.
system
(system)
Closed
7
