Starting a new job and I tried setting zeros
X Y as I always have done to the front left corner of the stock. When I hit start I am getting a msg that “ the project will hit the left of the machine “ .I have tried resetting the zeros several times but getting same msg. ???
This is a warning as noted at: Carbide Motion Bounds Checking | Carbide 3D Usually it is caused by a mismatch between job setup:
and how origin is set relative to the stock:
https://guides.carbide3d.com/running-shapeoko/movements-zeroing/
I find that opening the .c2d file up and drawing a box which matches the specified dimensions (draw up the cut in profile if need be) or moving the machine to the origin and then using a tape measure to measure out the dimension(s) in question will make clear where things aren’t lining up.
If that doesn’t help, upload the file and a pair of screen grabs from Carbide Motion showing Position and Machine Position (click to toggle) and a photo showing the stock clamped in place and the machine at a specified offset from zero.
You might want to run setup. Sometimes the wrong machine gets into the shapeoko.json file. Not often but it wont hurt to run setup.
Will,
This is a dead link
Moved to:
I did run setup and didn’t correct the problem
