Has Anyone field-tested to see what the actual peak and running Amperage draw is for the two models of HDM? I will be having 4-6 running at once and am examining the shops electrical setup.
If you can I would go 220v spindle and budget for 15 amps per unit even though the odds of you maxing out in the cut are very slim. 220v is more efficient and the extra power is great for drilling and bigger tooling.
What do you plan on producing with them?
