I have a 2.2kw ATC on the way and need to run a Z axis brake and I have 2 options and need some input.
I have a Teknic nema 23 brake for when I switch to clear path servos next year but it’s a 3/8" shaft and I don’t know if I can get a 8mm to 9.525mm adapter made as it would only be .7625mm wall thickness
I can easily mod a 8mm coupler for the ball screw connection Spring Applied Power-Off Brake: NEMA 23 | Teknic, Inc.
So do I try to make an adapter and run the Tecnic brake or try to find a nema 23 with a brake that would work.
I found a 3nm stepper with a brake but since Carbide won’t give us the specs I am not sure if I could swap it in.
My gut says try to make the brake I have work but if this stepper could be a drop in replacement it would help others that want to add a brake to their Z axis for a WAY better price.
I’m hoping someone knows if the HDM steppers are 1.8 degree or .9 degree and can point me in the right direction.
