I just installed a new HDZ with homing switches and recalibrated everything including tramming which was awesome with the HDZ.
I’m running my first project on the new setup which is a VCarve inlay for a cutting board. For some reason I’m getting very distinct ridges on my engrave/VCarve. See pictures below:
I’ve rerun the job a few times without much success. I’ve tried adjusting belt tension and vwheels. Any ideas what’s going on here? Before the HDZ install I did multiple VCarve inlay projects and they came out great.
I can’t open new Vcarve files, but the gcode looks like you were using a 60deg cutter?
Does that sound right? Are you sure you used the cutter angle you defined in V-Carve? (sorry to ask again)
It doesn’t say it (no comments at all), but I had a gut feeling (based on looking at the gcode in NCViewer). I’m downloading Camotics right now, but I may have to go to bed before I learn how to use it.
Can you click Edit and see what the parameters are for that bit?
Should be 15. That’s half of the angle…I don’t know why V-bits and engraving tools are defined differently.
By defining that half angle as 30deg, you’re saying you have a point that is 60deg.
You have that set as an engraving bit instead of a v-bit and the side angle as 30 degrees. According to the picture, the side angle is one side, so it should be set with a side angle of 15 degrees for a total angle of 30 degrees.
