Couldent find any hint on this … any idea?
From pg. 14 of:
The black plastic sledges are used on the off chance you have to remove a slider block. As the block slides off a rail, slide the sledge into the block. Please DO NOT remove a slider block unless advised to do so by support— ball bearings can fall out.
Somewhere in the instructions 3.3.1 they mention them a “Sledge”. They are if support tells you to remove the rails it holds the ball bearings in place. They stressed that to not take the rails off unless you are told to do so by support. I just put mine in a plastic bag and in a drawer with my Shapeoko parts.
Okay, thanks for the information…
