Is there a Carbide Create file for the “Hello World” Carbide Motion file users run during setup?
More to the point, what would be good settings to use for my toolpath if I want to preview a design using a Sharpie, before actually cutting the piece? Right now I created an “engraver” called Sharpie, with a 1mm diameter, no RPM, and setting my toolpath to contour - no offset, 0 DOC.
It would be nice to have a default, fast produced, “alpha test” of a design to hold in my hand and place gear against. I’m cutting foam inserts for Pelican cases for work.
So if I edit my “Sharpie” engraver tool (I assumed that was the best option, but correct me if I’m wrong), I can set the default plunge and feed, no problem. But how does the negative DOC work? Would that not “cut” above the surface zero?
