At first I could not get the Z axis low enough to do anything and then read a listing about removing one spring. That worked. Before removing the spring the Z axis would only lower an inch or 2 and chatter.
I ran Hello world and this is what I got.
Check that your belts are tight enough. If so, double check the set screw that attaches your gear to your motor shaft. One of the two set screws must be aligned with the flat edge of the motor shaft. You may want to use the Blue thread lock on that set screw.
I think I see this question come up almost weekly. The FAQ is clearly not so easy to find first, @ApolloCrowe can this get added to a troubleshooting section in an updated manual?
Thanks I will check that out.
