Help a newbie out
Things to start with:
  • machine level and all the parts square to each other and plumb?
Have you trammed your working area? I’d suggest adding a spoilboard and surfacing that:
For the actual cut you didn’t have geometry assigned:
and you are cutting out a simple outer profile / contour — this results in 100% tooling engagement and can be difficult for the machine to do. Best practice is to add geometry around things and cut as a pocket:
For your charming doll:
(assuming you wish to use a 1/8" endmill)
then modify the profile toolpath to start at the bottom of the pocket, and if desired have tabs:
Have you considered placing the image of the painted doll in the background and then drawing in all the features so that they could be cut as a V engraving so as to guide painting?
