HELP! CC Toolpaths with Wrong Tools in Motion
Just wanted to update. Like I said before, I created a copy of the project and started over with the toolpaths. I organized them to have the contours cut first, then the larger pockets with the 1/4" end mill and then the smaller pockets (.5" or less in size) with an 1/8" end mill and finally the cutout with the 1/4" again. Everything ran great until the smaller pockets with the 1/8" end mill. The depth of my stock is .743" and the toolpath called for a .5" pocket. Because of their horizontal size I wasn’t able to notice until after several of those pockets were cut that it actually cut to the .743" (I didn’t move the stock yet, so I can’t confirm that it didn’t go further). I double checked the toolpaths to make sure the depth was .5" and it was.
I would like to point out that at the first small pocket I found a small “pool” of oil. I’m wondering again if there might be something wrong with the Z-assembly, but since I’m not at home or able to look deeper at the mechanics of it, I’m going to look at my project file and the gcode export again.
For the record, I tightened the collet pretty good on the 1/8" end mill, so I’m pretty confident that it didn’t get pulled from the collet on the first pass.
I know there’s a debug mode in Motion, but it doesn’t seem like it keeps logs beyond what’s currently happening. Is there a way to keep a log to examine after the fact?
Open the Log window, then leave it open when running a job and it will accumulate all log messages — but may slow things down, possibly significantly.
Probably don’t want to do that with my “Motion laptop” then… it struggles with 8 tabs in Chrome. LOL Well, it was a thought. Thanks.
