Help! I broke text
So I downloaded the software and started playing with it. I clicked the text function and started playing with the settings like font and size then the text disappeared from the screen. Nothing I changed brought it back. I closed out the software and opened it back up but when I clicked text it came up with the same settings from last time for font and size that I put in. I then uninstalled the software and reinstalled it and it still came up with my last settings for text and still does not work. Any ideas? This is build 629
Is the text off the screen area?
Did you convert the text to curves or use it in a Boolean operation?
Please post the file you are having difficulty w/.
