I’m curious if anyone can point me in the direction of a resource for making the kind of slide together joinery that one often sees with flat pack furniture. Is there a name for the method used in the photos?
Interesting.
Should just be a matter of drawing parts up in profile/trigonometry, though I’d wonder how many times they could be disassembled/reassembled.
Hey, that’s actually pretty cool. Looks like it could be done with a dovetail or keyhole cutter.
Here’s a link to the assembly manual (Which can be zoomed in to see the patterns)
I think I would copy the bracket from the flat pattern & use that to lay out the slots in the leg & top.
Unfortunately, there is no flat top view of the table top. But you may need to make adjustments to accommodate your wood thickness & available cutters.
