Hey all,
I’m trying to make a couple of small 1’ round disc charms with some text engraved but i’m running into a issue. I don’t have the pro version of CC but I thought i could “cheat” by using a 501 pcb engraver with a contour toolpath. When i have the 501 selected in CC and take a look at the preview simulation, the toolpath is much larger then it should be. Am I doing something wrong here? Also, I would like to add a 1/8’ hole for a chain. What would be the best way to go about doing that? I’ve read using the drill path isn’t always a great idea. Thanks!
No, as far as I remember CC does not preview contour toolpaths correctly when using a V-shaped tool, so it renders as if the tool was a square endmill the diameter of the v bit/engraver selected. The cut should be just fine.
While endmills make for very poor drill bits indeed, for a single 1/8" hole in a thin disc (I suppose it’s thin?), it should work just fine to use a 1/8" square endmill and drill path
Download camotics. If will preview gcode.
Previewing V endmills when used for a contour toolpath was added in 629:
629
- (FIX) Contour toolpath simulation didn’t handle V-cutters correctly.
The problem is, the #501 and #502 endmills are entered as “Engravers” in current versions of Carbide Create:
(as is the Amana #45771-K)
and so can’t be used w/ V carving toolpaths:
(even though there’s no warning)
Instead, use a no-offset contour toolpath, and be sure to set the depth of cut to at least 0.047":
As noted, a Drill toolpath should be fine, so long as the feeds and speeds and plunge rate are appropriate for the material in question.
