HELP Me im stuck
Can anyone help,
Ive made a design on create, saved toolpaths and sent it to motion.
Its going to motion, but is only showing a very small part of the actual tool paths.
Also i can not seem to get my c2d file to show up in documents.
I seem to remember having this problem before, but for the life of me i cant remember how i sorted this last time, as ots been a long while
Upload your .c2d file here and let us know step-by-step how you are securing your stock and setting zero relative to it and managing all tool changes and post a photo showing an attempt at cutting still in place on the machine with the machine at the origin or a specified offset from that position.
My file is going over to motion, its just not correct
So run time is 32 mins, but when previewed on motion its saying 1 min 9 seconds and is not all there
If you are using the Send To Motion button, there has been issues with it. If so, use Load New File from Motion Screen.
Good Luck.
Ive tried but my file is not showing, im so confused, thanks for your help
Thank you, im so bad on computers, i was not saving it in the correct place
What version of Carbide Motion are you using? I seem to remember a fix for that at one point, try the latest version.
