Divchief07
(Steve McKaskey)
December 4, 2022, 3:40pm
1
I just finished setting up my Shapeoko 4XL and I should have known it was going too well.
On step 10.6 -Homing Machine, when I hit the Initialize machine switch I get a loud buzzing sound and the Z stepper is vibrating. It stops after several seconds then gives the message “Machine controller stopped unexpectedly and may be in an undefined state.”
I have tried starting everything over a few time to no avail.
Proximity switches all give red flight on them and blue in the controller.
Thanks in advance
WillAdams
(William Adams (Carbide 3D))
December 4, 2022, 3:49pm
2
Please write in to support@carbide3d.com
Things to check:
homing switches plugged in properly and signaling as the correct axis under Active Inputs?
machine able to move mechanically so as to activate each switch? Adjustment necessary?
Divchief07
(Steve McKaskey)
December 4, 2022, 3:51pm
3
Yep to both
I also have flashing red lights in the controller near the USB
It seems the Z axis is jammed up somehow
WillAdams
December 4, 2022, 4:09pm
4
Power off and turn the leadscrew so as to back it off the homing switch, then try again.
Divchief07
(Steve McKaskey)
December 4, 2022, 4:11pm
5
I did that twice
full up and down
I have also checked all the connections
As soon as I “Connect to cutter” I get the red lights. Normal or malfunction indication?
WillAdams
December 4, 2022, 4:19pm
6
Which red lights?
Divchief07
(Steve McKaskey)
December 4, 2022, 4:30pm
7
Inside the controller near the USB
WillAdams
December 4, 2022, 4:48pm
8
If you mean the lights for the homing switches, they should match the state of the lights on the switches themselves — please write in to support@carbide3d.com and we’ll do our best to assist.
Divchief07
(Steve McKaskey)
December 4, 2022, 6:27pm
9
No not those blue lights
I’ll write later and try and call tomorrow though I haven’t gotten any answer in several
calls
WillAdams
December 4, 2022, 6:46pm
10
Phone calls are returned in the order that they are received and mostly during the business week normal business hours (Chicago and California time).
Radiation
(Josh)
December 4, 2022, 10:00pm
11
I’d add that I’m not sure if missed calls are returned during the week. If possible please leave a message.
Divchief07
(Steve McKaskey)
December 10, 2022, 2:27pm
12
Well it turns out the groove in the controller connector is not where the clip fits! I had all the 4 wire plugs 90 deg off!!! All is well now
Thanks
system
(system)
Closed
January 9, 2023, 2:27pm
13
