do you want the result to be a “flat bottom” area with the edges of that shape be a V shape?
if so you are hitting a limit in carbide create
you can work around it by making 2 insets into your shape and use the “middle line” inset of a general pocketing operating, and the “inner inset” with your outer box for a vcarve path… we can help you get that but can you first confirm that this is what you wanted?
No no, I literally just want a border. A rectangle, who’s profile Inside is a V. When I draw a rectangle and then select V and run the simulation, it makes that path instead of just running 22” one way, turning 90 degrees and going 6” the other, etc.
Unfortunately, Carbide Create won’t properly preview a V endmill if used for a Toolpath | Contour operation. You can do so if you use a 3rd party previewing tool such as CAMotics.
I have used Aspire in the past, so I think I may just be expecting too much at the moment. I do want to use Create, because I’ll have the bitsetter and the probe and just like how it all “just works”
