Pretty simple… So I thought.
I’ve been designing/exporting objects to my 3d printer using Fusion 360 for a while now. Now that I’m comfortable with that, I’m exploring CNC machines and what I can do there. Before I purchase A Shapeoko 5 with a 4x4 bed, I want to be able to use full sheets of plywood (tile my projects) as I have a project, roughly 83"x’45" that I’ve designed in Fusion 360. I’ve exported it via stl file and cannot see it when I try to upload it Create Pro (on a trail version to see how it works.
I’m doing this as the learning curve to tile in Fusion is killing me. I have no problem generating a G code for the full sheet of plywood, but being that The Shapeoko 5 is limited to a 4x4 bed, I have to tile. Fusion has no easy way to do this, where CC pro seems a lot more user friendly here (lots of youtube tutorials steer me to that opinion)
No matter what I do, I can’t see any of my fusion files when I try to import. If I save the file to be opened by CCpro, the program opens and nothing shows. If I try to import, none of my saved SVG files show.
If I can’t get this to work easily, then I’ll have to look for a 48x96 CNC, which in reality is probably a lot easier for what I’m doing. Any advice/help… and no, I don’t want to tile in Fusion… 3 days of trying to get it to generate a G code that tiles with no success has me done.
Thanks, Steve
