We’ve been working on a wooden ornament design with detail logo and text, but can’t get the cut right. Are there any services out there that can set the file up with the correct bits and info? Tried Vcarve, engraver and other bits with no luck.
If you post an example of what you’re trying to do, i’m sure a few people will be able to help.
Post the file here, or send it in to projects@carbide3d.com and we will do our best to walk through this with you.
I wrote a bit about toolpaths at:
