rhende07
(Ross Henderson)
April 26, 2018, 10:11pm
1
Is there anyone out there who could help me with some very basic “get off the ground” stuff?
I draw some stuff in CC but when I go to CM and it asks me to LOAD, I can’t make it connect.
I have spent hours on this. Failing this part, would anyone like to buy a very lightly used XXL?
WillAdams
(William Adams (Carbide 3D))
April 26, 2018, 10:37pm
2
That’s what support@carbide3d.com is for — if you’re having trouble connecting to the machine using Carbide Motion see the article at: http://docs.carbide3d.com/software-faq/can-t-connect-to-machine-or-jog/
If that doesn’t cover it, contact us at support@carbide3d.com and we’ll get it sorted out.
REAVESPC
(PHILLP REAVES)
April 28, 2018, 5:57pm
3
Dont give up. We all had to work through the frustration of bugs of some sort. What version CM are you using? I found that reinstalling CM and hitting the reset on the controller solved it for me. Also make sure your USB cable is fully connected.
system
(system)
Closed
May 28, 2018, 5:58pm
4
