Receiving this message
See:
https://carbide3d.com/blog/carbide-motion-bounds-checking/
I find it helpful to compare the physical position of the Stock and the zero relative to it on the machine, the wireframe preview in Carbide Motion and the file in Carbide Create — if need be, draw a rectangle the size of the XY dimensions given in the message positioned at the origin.
Also check the Safety/Retract height.
Did you set the workpiece zero BEFORE loading the file?
Yes I did… Actually moved workpiece to different location and it worked. Now having issues with VFD spindle. VFD is flashing 0.0 with FWD and HZ lights on. Trying to reset to 10,000 and/or change RPM…Thank you so very much
