Help with MELD Vectors
I am new to the SW… I did purchase the PRO version…
I assume the pink in here is because I have multiple vectors, but I can’t find a way to MELD them.
Can someone please explain what I am missing or how to meld everything together.
Thank You.
select the pink line then go to join vectors under edit
Thank You… I overlooked it… Rookie mistake.
Meld, Union, Intersection, subtract… boolean operations are for closed (black) vectors only.
For open vectors (magenta, pink), use the Edit node, Trim & Join tools. Or try out the new region builder.
