I am attempting my first aluminum project in carbide create to perform with my Nomad 883 and there are some things I’m not sure if I have right in the software. I am most confused about adding a new tool.
I am trying to etch out a leaf design and then cut it out to make a small pendent.
but when homing, please use a feeler gauge of a thickness to make up for the tip.
Note that V endmills in Carbide Create are only properly previewed in 3D when used for V carves. You’ll need to offset the paths to create a closed region you can use for a V carving to adjust for that lack.
Thanks so much for taking the time to give me this info!
Its really helpful, though I haven’t had a chance to test it out yet. (darn day job)
I am also looking at Fusion 360 as a software solution and I’m looking through its courses now. I’m assuming adding custom tools/endmills is a similar process in that?
