Hi hope some one can help me since i updated carbide to v7 i am having a coupek issues. Not sure if me or machine
When i load the file on to gsender and set my xyz zero i will click start and then it will dive the bit straight down into the piece i have the zero set at top of piece and my safe z height is 3mm.
Since i updated to v7 did i miss a step in my set up. Hope i got this across clearly as i struggle with communicating it
Please help i have limited hair left to pull out on this cheers.
Where do you have the origin set in the .c2d file?
Please see:
If that doesn’t address your difficulties, please post the .c2d file (or send it to support@carbide3d.com) and let us know step-by-step how you are securing your stock, and setting zero relative to it, and managing all tool changes, and include a photo showing an attempt at cutting still in place on the machine.
Do you mean for start point is lower left.
My apologies i thought i said it in th e orional post it is set to top of piece.
