I got a z probe to do a semi-automatic tool change, its normally closed.
The problem is that I cannot mix this probe with a touch plate because it’s normally open, its there a way to use the estop pins to use the the z probe?
If not, I can make a normally closed touch plate, but don´t know if I can set grbl to use it in that way.
