I upgraded the spindle bracket on my S03 to give it added rigidity when machining aluminum and garolite XX. I’m not sure if it’s the added weight on the Z-Plate or the fact that I made the belt much tighter. But now the stepper calibration is off.
The nominal depth of the slot on this part is 5.338mm and it’s measuring at 7.67mm.
Let me know if my math is wrong, but from my understanding…
5.338 / 7.67 = .696
40 x .696 = 27.838
So in Carbide Motion MDI I should type in $102=27.838
But my issues is when I type that in and hit send, the offset doesn’t change and the $102 value just stays at 40. The output is this:
(797): <- ok
(796): <- [GC:G0 G54 G17 G21 G90 G94 M5 M9 M56 T0 F4000 S0]
(795): -> $G
(794): -> gc_parser_state
(793): <- ok
(792): <- [PRB:0.000,0.000,0.000:0]
(791): <- [TLO:0.000]
(790): <- [G92:0.000,0.000,0.000]
(789): <- [G30:0.000,0.000,0.000]
(788): <- [G28:0.000,0.000,0.000]
(787): <- [G59:0.000,0.000,0.000]
(786): <- [G58:0.000,0.000,0.000]
(785): <- [G57:0.000,0.000,0.000]
(784): <- [G56:0.000,0.000,0.000]
(783): <- [G55:0.000,0.000,0.000]
(782): <- [G54:0.000,0.000,0.000]
(781): -> $#
(780): -> gc_get_offsets
(779): <- <Idle|MPos:-5.000,-5.000,-7.184|Bf:14,128|FS:0,0>
(778): -> gc_sync
(777): <- ok
(776): -> $102=27.838
(775): -> gc_not_motion
This is my grbl version and CM version:
EDIT: One more thing to mention that is really strange. Is I have a digital indicator and when I mount it to the Z plate and jog the z plate down 1mm the indicator reads 0.95mm. Which makes me wonder if the issue is in the program?
***Another thought, I have used UGS and PicSender for the Jtech Photonics laser I have. I wonder if the settings from one program for grbl interferes with the others? I use PicSender for the laser. And there have been times when the CNC acted weird and I just found out if I would go back into CM and hit send config that it would fix itself.
Would it be optimal at this point to just reflash the firmware to standard grbl1.1 and get rid of PicSender and UGS and just restart from scratch?
Your help is appreciated, because I have 13 customer orders to fulfill which is around $8,000 in business for me and it’s halted because of this issue.
This is my website for those that are curious.
www.turnracing.com
Thanks
