This is not exactly 45°, but the user didn’t specifically ask for an exact angle, just that the roof peak was longer, which would require 2 different angles.
The last time something like this came up, my solution was two separate files/models — my understanding is CC Pro is a modeler for decorative use, not a replacement for a full-fledged 3D CAD program — I believe it’s an accepted limitation that not all geometry can be accurately modeled/cut.
Agreed. And even though I inadvertently dimensioned it with 3 decimal places, the tolerance is indeed “decorative”.
One big brain cramp I’m getting with this 3D stuff is… if I create a shape that extends outside of the workpiece, the shape gets limited to the workpiece. So in this case, if I drew a rectangle on the left that extended 3" outside the workpiece, and 3" inside the workpiece, and made it at least 6" taller than the workpiece, then subtracted an angled shape, I would think it would build the angled shape using my whole rectangle, and just subtract one side of the angled shape. Yet it forces the angled shape to be entirely inside the workpiece limiting it to 3" wide no matter how big I make the rectangle outside of the workpiece.
The green solid is my finished part, and it’s base is the size of the workpiece.
The grey solid is what I would expect if I drew it’s base with 1 edge 3" inside my part, and the other 3 sides 3" outside of the part.
