Is there a standard process for hogging out material with 1/4" bit around lettering and then coming back with detail with a 1/8" bit? Obviously, I could just run a duplicate tool path, but that seems like a waste of time.
You are describing ārest machiningā. It is a feature available in CC PRO.
For the free version of CC, you can do the āpocket then contourā trick:
Thank you so much! That looks like it will work perfectly.
