Hi all -
Had a quick look across the forum, but cant find an answer.
I am running a batch job of parts - all the same, utilising 1 tool, machining time is around 3 minutes.
I also use a bit setter.
To decrease the overall cycle time between parts, I would like to change the home position after machining slighlty away from the job, not all the way to the back of the wasteboard and also remove the bit setting cycle at the start of every job.
I know I can turn off the bit setter setting to overcome the later but can this be acomplished in the G code file?
…the machining cycle is 3 minutes and I am probably wasting near 3 minutes again waiting for the head to travel to and from the far away home position and cycling the tool on the bit setter.
Any advice would be warmly received. I am sure @Julien will have some ideas!
Example .nc attached
example.nc (18.7 KB)
