Hello ! Bought this awesome machine, went through some issues with missing hardware ( UPS ) fault, and I finally got it assembled. Wiring was an issue, so I looked through the 6 million google posts about wiring and finally got it solved. ISSUE I am having, is when I go to new machine setup, it connects to the machine, then I get to that cool dialog box where your supposed to be able to test the prox switches. Your supposed to be able to select any one of the 3, but it does not allow that. SO I hit the next step and right away I get a homing error.
The Z axis carriage is full up, the red light is on.
The Y and X switched will light if triggered with metal.
The gantry when power is off moves fine X and Y
I have painstakingly checked the wiring and nothing is reversed.
Once in awhile, it’ll have that stripped gear sound. NOTHING moves.
Id like to moved the Z axis down away from the prox switch but I don’t see any way to manually turn it to a lower setting.
Any Idea’s? This is so gd frustrating I cannot fully express it.
Thanks!
Steve
Basically same issue as this poor guy here, unresolved as far as the post is concerned.
I received my Shapeoko 5 pro about a month ago and still have not got it to run.
The assembly was easy enough and went smoothly. But, when I go through the machine setup wizard on Carbide Motion I get the same error ever time.
The error happens on the homing switch test portion of the machine setup wizard. It has the “Home Y” selected and I cant change to any of the other home options. When I click the “Initialize Machine” the machine y motors start to spin and go back to -10 y position and then an error message says “There was an error during the homing process: Carbide Motion was unable to move off of the homing switches.There could be a hardware problem or something keeping the machine from moving”.
I have been back and forth with customer service. They sent me new switches, still have the same error. Then the send a new controller, same error. And finally they sent me a new electronics harness, still have the same error.
I am getting frustrated and hope that once I finally get the machine running that it isn’t faulty and plagued with issues. But, mainly just want to get the setup done to start planned projects.
Has anyone had a similar experience? Could it me faulty motors? The machine is square and level and the gantry moves when I manually slide it.
I am using a AMD Lenovo ideaPad with 20GB Ram running windows 11.
Thanks for any help!
