can anyone help me with this? I have a pro xl
These types of failures could be you need to adjust the switch closer to the trigger. Sometimes the sensor gets loose. Move your machine to the homing position and adjust the sensor as close as possible without actually contacting.
If you have verified the sensor has not failed you can power up, connect but do not initialize. Then go to settings and put a metal object on the homing switches and see if they show as triggered as an active input. Also the proximity switch will have a red light that illuminates. If the switch does not trigger with the metal object it could be a bad sensor. Usually just needs adjusting.
