Hello,
Currently I am facing Homing Cycle Failed error on Carbide Motion when I am sending configuration for the first time after mounting the Shapeoko Pro.
Please help.
Hello,
Please help.
Power on machine but do not initalize. Check prox switches and make sure they are working. The instructions have you set the switch too high to trigger. Power off machine and push carriage to x and y home, one at a time and see of switch is triggered and adjust as necessary. The config needs to be sent so proper z is set. The cm interface will show if switch is triggered. You can manually move z-plus up by turning screw to test z prox switch. Then try to initalize.
